low pressure at windscreen washer jets
4 Jan 2011
Durham
as title. Topped it up still get a trickle out the lets thought might have been frozen so been checking over last few weeks no change? Is the pump knackered? Do you think that could be due to freezing? Car is a hyundia accent r reg
i had the same problem on da bimmer.. turns out theres a filter on the end of the pump which was blocked.
Could be a number of things.
Blocked jets. Even if you poke them with a pin they may be blocked inside. Should be easily removable to clean.
Blocked piping. Pull the pipe off the jet and see what happens
Split piping. More likely if it froze.
Blocked filter as someone else said.
Duff motor/pump. Pull pipe off jets and see what happens.
