Yesterday I saw that the pressure was low (below 0.5 bar) on the central heating. That occurred after the radiator didn't started last night with the broken flame symbol.
I spoke to one of my neighbours and told me to refill the central system, and which valve it is under the combi boiler.
I turned it on, the gauge jump to 1 bar, left it for 5 minutes and turned it off. Then dropped back again bellow to 0.5 bar, while the boiler stopped working again. After few tries dismayed a friend of mine told me to leave the cold water on, and turn on all the radiators in the house.
I live in a two storey house, and I have the top rads off for many years since I am not using the top bedroom, nor the ground floor.
After 2 hours, while the heating was still on, and the cold water also decided to close it. The rads started warming up after I turned off the cold water while the pressure remained just above 0.5 bar. (at least had some heat).
Now, I had a look around the house and I cannot see any leaks. In addition the top floor rads one gets barely warm the others not at all.
Tried to bleed them with the key, one of them had bit air in there, needed around 15 minutes to stop air coming through, the others are dead empty.
I am completely new to this area of DYI and I would like your feedback how to solve the problem.
More info.
Since last night when I had the water on, I can hear water movement inside the rads, the ones that were working fine all those year.
When the boiler is working now hits the 1 bar, when stops drops below 0.5
The house is 2007 build and bought it from new in 2008, before the divorce, where I stayed on the house on my own. (hence not warming the top bedrooms).
The boiler is LPG one, since the whole estate is on a central LPG tank-supply.
Now reading the sticky above it says to turn off the boiler completely and turn on the water until it hits 1+ bars. Is that correct?
However when my boiler is off, no water can be heard from the cold water pipe (which is pretty hot right now when is working on with the rad).
I should have a pump working upstairs, but cannot hear it at all, while the cupboard where it is, there are too many pipes around and I have no clue what is what.
Thank you for your assistance.
EDIT
Took some pics of the system.
Boiler (ground floor). The valve that seems is working is the left one
Cupboard with the rest of the plumbing
More info.
EDIT
