Low water pressure for a shower
2VN
25 Sep 2003
Want to install a panel shower onto a combi boiler but the water pressure is low, cant fit a pump .... any ideas
dont know if these can be used on a combi boiler, but I wanted to fit a shower without a pumped hot water system.
I was recommended a 'Trevi' 'Boost', this uses mains pressure cold feed and with a fancy bit of magic inside it, using the cold preasure it gives a boosted hot. Dont know how it does it, but it works.
Costs a little bit more than a standard mixer shower but well worth it.
Got mine from Jewsons
http://www.trevishowers.co.uk/treviboost.asp
Sorry 2VN you're stuffed. You cannot pump a combi 's water, in or out. What combi is it? At shower temop you should be getting around 9 litres per minute, at least. Not enough anyway for a set of sprays.
Is there a combi that could?????????? I doubt it
Sorry mate aint going to happen :shock:
