Low water pressure in flats Pump and combi
12 Feb 2011
South Glamorgan
I have 3 sef contained flats which run from the same common water supply.
The problem is that they suffer form low pressure when at least one tap is open.
After talking to neighbours it seems its a common theme even in singular households dependant on time of day.
Has anybody experience of using cold water storage tank and a pump to feed the combi and cold water supply.
i am proposing to do this to each flat.
Ashoge
Done it several times over the years.
You are referring to a break-tank setup.
Also consider the idea of an accumulator depending on the ACTUAL cause of the problem.
actually each flat should have its own supply from the street...
