D
david and julie
I am about to fit a maserator toilet on a boat. The waste will be pumped into an onboard waste holding tank. The holding tank is about 10 metres away on almost the same level, there is hardly any uphill pumping involved. I have had conflicting advice regarding the outlet pipework so would welcome any comment. The working principle of the toilet is the same as a domestic one except they are only 12V.
1. The makers booklet only says the pipe should be 1" wastepipe. It doesn't say any particular type of material.
2. The chandlers say you need odoursafe pipe at £15 per metre
3. Plumbing friends have said they use either overflow pipe or 32mm waste pipe (both solvent welded)and have had no problems.
4. Another guy I know (a building inspector) said ideally sanitary grade pipe is better, but didn't elaborate on as to why this was so.
What would you people use if you fitted one?
