I have a large metal gate with a CDVI ES500 Maglock on it which was replaced like-for-like after the old ES500 was damaged. The contact monitoring does not work correctly on this new unit though - the contacts are always closed (indicating the gate is always locked). The wiring is correct, and when demounted, or even moved 5cm away from the metal, the lock works ok. A shim or rubber washer between the lock and gate doesn't help. Has anyone any experience of this? Any ideas how to monitor the status of a metal gate? CDVI technical support say they do not produce any products suitable for mounting on metal frames.
