I need to install a Magnetic Filter as my system is getting blocked with sludge, mainly the expansion vessel but no doubt elsewhere. System is 10 years old and not far off full replacement but need to keep going for a bit. Boiler is Baxi Megaflo 2 system 12 compact GA.
From my limited knowledge I would need to fitter on the return flow to the boiler however as per the image below and highlighted area there is limited space. The pipe bends into the wall and then is behind plasterboard for about 20cm down to the plinth and then worktop. I can’t easily remove the plinth or worktop without a lot of effort and fix up but could possibly cut out the plasterboard and fit onto the pipe. It feels tight to me but has anyone had a similar challenge? Are there any good filters that have a more compact fitting/profile?
The other option is that I find the return flow next to the hot water tank located on the first floor. Would this be better option? TIA
