Mains pressure
h10tug said:
Why can I not put a pump on the mains supply to increase the pressure in the house?
1. If you pump at a rate more than 12l/m then you need written permission from your water undertaker.
2. If you pump at a rate more than the supply can provide, then you'll do what Dan said.
3. You can't consistently pump more from the mains that the mains can provide under its own pressure. It's a non sequitur.
