There's a nice cheap second hand front uPVC front door but I measured my opening brick to brick and it's a little on the large size:
2071 x 921 mm (81.53" x 36.25")
Where as this door (including frame) is only 33" wide, so I'd need to do something to "make it bigger". What do you do in this situation? I've read something about frame extenders, but that seems like quite a lot of frame extenders. Can it be made to work? (Another later idea: Add some wooden timber around the uPVC one, can you do this?) It's worth a bit of effort cause the door is in good nick and a similar one made to measure would cost a couple of hundred quid more.
Also looking at another nice new (and expensive door) which is the right width but too short without a cill and too big with one. What can you do in this situation? I'd lose some of the doorstep but then you'd have another step as soon as you open the door! (Later idea: I could make the door step a bit bigger)
I also wondered if you can widen the masonry gap a teeny bit with a grinder if you don't mess with the lintel because I got the reverse problem with the back door. This something door fitters ever do?
