I recently completed construction of a man cave, at the end of our c. 30m garden.
It comes complete with electric, water, WC and a bar. Excepting that I want to stream online TV down there, I need never leave.
Unfortunately I didn't run any CAT5 down the garden when the builders had a trench dug for drains. So, I now need to connect to our WiFi down the length of the garden from the house.
Given that I need a new router anyway, this may not be a massively expensive omission. But, I want to leave my router sited at the opposite end of the house to the garden. Basically meaning I need to boost the Wifi signal across then house then down the garden.
I've done the obligatory internet research and found a plethora of WiFi repeaters, extenders, external and internal antennae. All of this leaves me no nearer a solution, just more confused.
So, in short, have any of your good selves had (and solved) a similar problem? Can you recommend good (or warn of bad) hardware to solve my connectivity issue.
Many thanks.
Many thanks.
