Hello again people,
I have been doing P.A.Testing for the first time as some of you know.
The tester i have is a Martindale Easy PAT 2100.It seems quite the alrite little tester actually.
Theres just 3 things im not too sure about.
-There is a black lead supplied with the tester, which has a crocodile clip on one end and 3 pins on the other which plugs into the tester and next to where it plugs in it says "Earth to appliance".I have gatherd that this is to test the metal work on class 1 equipment by clipping the crocodile clip onto the metal work.is this correct? and if so what sort of results should i get to pass?
http://www.google.co.uk/imgres?q=ma...rt=32&ndsp=10&ved=1t:429,r:5,s:32&tx=78&ty=72
-The flash test with the flash gun .In training i was told not to use this as it can be very dangerous he explained it injects a high voltage into appliances or somthing or another.Could any1 expand on this ?
-Also another thing, i have P.A.Tested a 3 gang extension lead.In last years test it was tested by a P.A.Testing company and for contiuity it got 0.8ohms and now when i press the test it gets around 1.5 ohms.why would this happen?is this acceptable?
Cheers guys Much Obliged
