Hi
I have a Megaflo CL210 that I periodically have to replenish the airgap and wondered whether someone could answer a couple of questions I have.
Firstly when I replenish the air gap and open TPR valve it seems to take at least 20 minutes and can still hear gurgling. I have noticed that the height of the TPR and the lowest tap are a very similar height could this be why it takes so long. I can see a drain off cock on the megaflo can this be used to quicken the process.
Also the red expansion vessel, what should the pressure be set to on this.
The reason I ask is that ever since we moved in the pressure has not been brilliant if the bath and shower are running at the same time. I would assume that this type of system should be able to cope with a couple of taps running at the same time.
Thank you in advance for any replies
