Melamine faced ply for wardrobe doors
28 Mar 2013
Brecknockshire
Hi, I would like to construct a built in wardrobe with three bottom track sliding doors. I was thinking about using these sheets
https://www.slhardwoods.co.uk/produ...te-melamine-faced-birch-plywood-2440-x-1220mm
They range from 9mm to 18mm thick. I think the heaviest grade will be about 30+ kg each sheet. Can anyone offer advice whether they are sufficiently stiff to stand on the bottom track rollers and support their own weight without bowing. I would like to use the thinest possible for aesthetic reasons and because they are cheeper.
Thanks for your help.
You are always better off with top hung doors if straightness is an issue
Thanks for the replies. Ready made doors are not the right size. Top hung, good point. I will look into that. Thanks,
