Not sure about fault code but post a photo of the rear of the machine to see if the heating element is easily accessible for inspection.
Most likely fault is the heating element has failed especially if the machine is fully working but just not producing heat.
Has the dryer been well maintained?
Thanks for that, will inspect element tomorrow. Rear panel has 5 screws so easy to access element. Drier has been religiously cleaned when required i.e. filters cleared etc. No other probs since new.
Inspect heater and report back. Should be obvious if heater has failed.
Whilst back is off you could test thermostats if you have a meter.
Be sure the plug is removed from the mains socket.
