Minimum pressure to operate a toilet fill valve
16 Jul 2009
Hull
Does anyone no roughly the minimum pressure required to operate a toilet flush valve? Thanks
A flush valve? No pressure is required, the mechanism lifts and the cistern empties into the pan. Not sure what you mean.
Trick question .title refers to fill valve and content of post refers to flush valve.
Answer to both is not very much, roughly !!
Thanks its a grohe concealed cistern one, any idea if these are low pressure? I'll ring technical tomorrow.
A lot of the valves are low pressure by default and then you either insert or remove a filter/reducing insert supply dependent.
