Mira 10.8 cable fitting
7 Dec 2004
Hi
I'm installing a 10.8 Mira shower, have everything in place, plumber coming to connect up the water etc. However, the 10mm cable is coming in from the top of the shower, then has to bend back up on itself to go up to the mounting block. It ends up with a very tight bend in the cable, and there's not a lot of room for manoeuvre anyway - is that safe, or would I be better using a short run of 6mm to a junction box in the loft, and take the 10mm run from there?
tight bends shouldn't be a problem as long as the cables are well secured in the terminals
It is however worth stripping enough of the outer jacket to allow the cores to be bent up separately, and pre form them to the right S shape, don't try to make the terminals pull-in against a springy cable, they should be quite relaxed.
The terminals are quite weak on some Mira showers, and there is a risk of tail wagging the dog - the cable is fine, its the stress on the connection screws that can be the problem, and while 6mm is softer than 10, the observation still applies.
Gavin0268 said:
Hi
Sounds like you've got the cable going into the shower at the wrong place or in the wrong direction. Why didn't you have it entering the back of the shower at a comfortable angle?
