- Joined
- 14 Oct 2024
- Messages
- 14
- Reaction score
- 0
- Country
I have freshly plastered room that has properly dried. One of the walls has 3 spot lights directly above which highlights any and every imperfection of an evening - by day it looks fine.
I mist-coated the plaster with fresh plaster paint then add 2 top coats of Wilko washable paint. By day looked fine but of an evening under lights some areas are smoother thank others - I think there where different textures from the mist-coat which are causing the top coat imperfections.
So I have stripped the paint off, lightly sanded the plaster and miss-coated again. Now that this has dried I can again see the different texture in parts (very slightly pited i guess from the nap of the fine roller) so I'm holding fire on the top coat.
Question being - should I lightly sand the mist-coat with the aim of having a totally flat finish. I don't really mind if the finish is slightly texture or flat - it just needs to be consistent and since I don't seem be able to add the texture to the flat parts making it instead dead flat seems the way to go?
This is driving me mad - any suggestions.
Thanks.
Thanks.
