Is it ok to mix plasterboard and aquapanel in either of these ways
1: Along the same wall like this, wall needs say 3 sheets of board. First sheet normal plasterboard then next two sheets aquapanel.
2: Wall needs the same 3 sheets but is going to have a double skin of boards, like so. First layer of boards normal or water resistant board, overplated wiith 1 normal plasterboard then 2 aquapanels.
I ask this question because i though cement based stuff caused a problem with plaster. Example, needing to put primer on skimmed plaster walls before using cement based tile cement. Or have i got this wrong.
