Mixing render and plaster
1 Oct 2007
Hampshire
Currently stripping off the un-bonded skim in an extension. Base coat is sand / cement render. Large area needs new base coat. Is it an issue to use regular base coat plaster, or would I need to stick with render?
Cheers,
Fubar.
hate to do it... but....
bump.
Need to get this job done this weekend if it's a goer.
Cheers,
Fubar.
Ideally sand cement, but if there are no issues like damp then any basecoat.
It might be that fill th ehole iwht bonding and give the whole lot a thin coat to make it nicer for skimming, as long as prepped ok
Cheers Micilin,
No visible evidence of damp that I can see in the areas in question.
I'm planning on base coating and getting the walls flat myself, then paying a plasterer to come in an skim for the professional look.
Will double check tomorrow and fling the stuff up.
Fubar.
