monsoon pump
26 Sep 2009
London
Fitted a monsoon pump to a bath & shower,teed off before the pump because the customer did not want pumped supply to his wc and basin.Trouble is,whenever the basin taps or wc is used,the pump comes on for a second ,then goes off again.I guess the slight movement of water causes the flowswitch to trip.
I am thinking about fitting non return valves just before the pump,I just wonder if anyone has any ideas? I can't change any pipework because the floor has all been tiled over.
you can fit nrv after the pump not before, the pump needs to vent back to cylinder etc.
