Apologies for starting another Motorised valve thread!
I've had a good search through so think I know what the problem is but wanted some opinions please.
We moved into our house about a year ago. We had some problems with the general heating but after changing the MV actuator all seemed ok. The MV is a Danfoss 3 port. Obviously the heating's been off until recently. Now to activate the heating we have to manually slide the MV leaver across for the radiators to warm up. As far as I can tell this is because a, the actuator has a problem or b, the valve is a bit seized?
Last night I took the head off the MV and clicked the heating on and off at the room stat, the head seemed to be working fine. The small half moon bit that the head controls moved by hand but seemed a bit tight. I moved it back and forth a few times put the head back on and the rads warmed this morning without me having to manually move the MV lever.
Now what I can't work out is is it because the valve was a bit stiff and I freed it last night or is it because the head motor is a bit knackered and hasn't got the power to move the valve its self, or is it a bit of both!??
How feely should the valve move?
thanks
thanks
