L
Lincsbodger
The central heating in this bungalow is very old, but works top class. However , ive got to move the timeswitch, because the kitchen is being restyled.
SO, not sure how they wire these things. Without taking it to bits, what i see is a mains wire going in from a double pole isolator switch, then two cables coming out the other side. One goes to the pump and the other to the boiler.
However, theres a room stat, and i cant see how its wired in.
Presumably, the incoming mains goes across the L-N incoming pins on the time switch, and the boiler and pump are in parallel across the switched output, but in series with the room stat ?
Like this?
Like this?
