Hello,
So I would like to have fitted a Multi-Fuel / Wood burner stove in a smokeless zone and after much research and talking to shops and HETAS installers. I am so confused that I am thinking of just bricking up the hole where the fire place was removed from and putting a jug of flowers on the hearth.
(1) Two HETAS installers/shops tell me I HAVE to have a dual skin 6” fuel from a 5” stove. So I show them the photos and the detailed measurements (160mmx250mm chimney) I have made of the flue and explain to them it is too narrow to take a 6” flue pipe also the chimney has a bend in it half way up and they will never get a 6” dual skin down it. Oh well then under those circumstances you will HAVE to have a flexible 5” single skin lines.
(2) Two other HETAS installers tell me I have a perfectly good external brick built chimney that is in good order and has worked perfectly with a coal/smokeless fuel open fire for the last fifty years. So I don’t need a liner they just put the stove pipe through the registration plate and back seal it with vermiculite V shaped wedge that steers any debris that drops back into the stove. Or the T piece if the stove is rear flue’d.
(3) Another HETAS installer tells me that liners are only guaranteed for 10 years and therefore maybe prone to problems in the long terms. So you’re better off with your good old chimney that will probably if regularly checked/maintained last the life of the house.
Then when I finally find a stove that fits my requirements. The install instructions says solution (2) can not be implemented as the end of the pipe must be 3” from the chimney wall. Maybe the vermiculite V shape will full fill this requirement?
Any ideas what going?
Been HET-AS'sed
Tried to add picture but this alBUM does not seems to work
Been HET-AS'sed
