My megaflow tank is squealing
5 Oct 2014
Cheshire
Hi my megaflow system hot water tank is making a squealing sound , any ideas please ?
Glynn
has it dishcharged any water out of the pressure relief pipe.
they have an internal air bubble baffle that traps air in the top of the cylinder. the air bubble air absorbs the expansion of water when you heat it up. its required that the air bubble is regenerated every 12 months to stop excessive working pressure, it normally states how to do this on the side of the newer models
I have found that the cold water inlet group can make a bit of a racket but havent found what causes it, usually just change it and the noise stops.
It's not leaking any water , just making an awful screeching noise .
I've turned the electric supply off at the mains
