- Joined
- 9 Feb 2014
- Messages
- 4
- Reaction score
- 0
- Country
Hi guys, I'm really hoping someone on here might be able to help me out.
This morning I noticed the red flame/temp light illuminated on my boiler and I couldn't get hot water or central heating. I reset the boiler and all seemed fine; until this evening. I noticed the place was quite cold, even though the heating should have been on. When I went back to look at the boiler, I noticed it was continuously firing up, over and over again. The hot water seems to work perfectly fine though.
The fan will start, so will the pump, the gas flow and ignites. Then after a few seconds, the fan will shut off, then maybe 10s later, the gas will cut off. The whole thing repeats itself over and over. I have checked the thermistor which is in tolerance. Reading over the forums I'm beginning to suspect it could be the fan PCB - I just need someone to give me the confidence to order it.
Is there anything else I could check?! Andy advice appreciated.
Best regards,
Andy
Best regards,
Andy
