My Mums outside waste trap where her washing machine vents dirty water has crumbled due to plants and the fact that 25+ years ago it was done as a quick and dirty bodge !!!
I have just removed most of bits to find:
1) There isn’t actually a trap at all, I assume there should be?
2) The bit under the grate (gulley?) is just a small cement chamber with a bit of black downpipe (I think as its about 70mm) which has been cemented in the bottom and which is connected to the foul water drain a couple of meters away.
3) The cement chamber, which has fallen apart, was just done straight on top of un-compacted soil.
I hate bodged jobs but most of the drains around my mum’s house (waste and foul) are going to be replaced in a few months as we are building a new house nearby and it’s a good opportunity to replace her terrible drains at not too much cost.
So I am looking for a quick and dirty solution. I had thought of just connecting the outside 40mm waste water pipe from the washing machine inside trap directly to the bit of 70mm pipe but I can’t find a connector that would allow me to connect a 40mm waste pipe to a 68mm? Downpipe. Does anyone know if such a thing exists?
If I can’t connect the pipes and I have to build a new trap, what should I do, is the following correct:
1) Dig out hole, compact and line with sand/gravel?
2) Build chamber with brick/cement/concrete? Or purchase if purchase what do I need?
Or does anyone have another perefrably simple option?
Lastly, could someone explain why every time I decide to do what I think is a minor DIY job it turns out to be much much more complex that I was expecting
