NEED A UPVC FRONT WITH NO HANDLE OUTSIDE
13 Jul 2008
Lancashire
MY PVC FRONT DOOR AS A OUTSIDE HANDLE ,ANYONE CAN AND DOES JUST WALK IN WITHOUT KNOCKING , SO RATHER THEN LEAVING THE KEY IN THE DOOR LOCKED SO IT COULD BE KNICKED
(HAND IN LETTER BOX VERY EASY DONE )
CAN I BUY I NEW WITHOUT THE OUTSIDE HANDLE IF SO WHERE FROM
You can get a door with a lever / pad handle set, which basically works like a normal door from inside, but has a fixed handle on the outside where you will need a key to get in.
You could always lock it & hang the key on a hidden hook close by.
i hate to be the bearer of bad news but you cannot just change the handle set the lock needs to have a split spindal so the lock operates from the inside but u have to use the key to operate the latch from outside,a new lock maybe required.
Best regards
Alan
i changed it to a split spindal mec and handle/pad and its brill .. keeps all the rif-raf out
....i wish i'd got one year ago :D thanx 4 the help ...
