Right as some of you will know, i fitted a shower pump yesterday.
The shower and pump all work fine, however, the basin cold tap doesnt.
The tap is fed from the CWS tank in the loft (which is full). I shut the gate valve and took the nut off and ran some water into a bucket fine... So the problem's after this point. Where I'd taken the nut off, i tried blowing down the pipe (with the tap open), and i couldn't blow down it - I nearly popped!
So could this be an air lock, or is it blocked or what? And how could i fix it
Help me please
Thanks in advance.
David.
Help me please
Thanks in advance.
David.
