bar steward....a leak in my own house, can you believe it.
shall i charge myself a call out fee ?
Can i do the job on sunday...dbl pay ?
Or shall i ignore it hope it goes away?
Take approx measurements of the patch from a datum point downstairs but which can be located in the 1st floor area of the leak ( eg house or dividing wall ) . Locate the rough area of the leak upstairs and you'll likely find it's a leaking shower or bath waste. Don't replace boards until you've rechecked thoroughly as sometimes 2 leaks can occur which run to the same low point in your ceiling.a brown patch has appeared on my ceiling...can you help
Since you're a plumber, let me know when you've a brown patch on the floor as I'm a sewage worker !a brown patch has appeared on my ceiling...can you help
