Hi
I had posted few days ago my potterton puma was not lighting up, pilot flame kept dying, it sorted itself out and started working fine, or so I thought.
Well yesterday it packed up completely, the pilot light is on but when I put the hot water on the big flame is not starting, its the same for CH AND HW. I called two guys around to have a look and they said its gone, we could repair it but there will be no warranties of how long they will work for.
So finally I think I have made up my mind to get a new boiler, I was recommended either Main or Valliant eco tec pro 28. Are these the right choices.
I have looked on the forum and Intergas seems to be the favourite, would the installer charge me extra on that.
I have a standard 2 bed semi and one bath, my potterton puma 80 i think is 24kw.
What would you recommend to replace it with.
Also the quote for Val eco tec pro 24 is 1700 pounds supply and fit, does this price sound right.
I have another guy who is saying you get the boiler and I do the fitting for 700.
Also one more important thing after the survey they found out that my pipe coming in to the property is 22mm but what is going into the boiler is 15mm, they said we will need to check the pressure and if the pressure is correct we can install the boiler on a 15mm pipe.
Is that correct or does the regulation need a 22mm pipe.
