Hi all.
A couple of weeks ago I emptied the system to change a few faulty, old, rusty, leaking valves..
All went fine, and the heating system works way better than before. But one radiator is causing a problem.
Basically I removed the old valve - which basically fell off in my hand, turns out that the actual pipe from the floor was cut to short and the previos valve was barely attached. When it came to replacing it I ended up using a valve with an extender....it's this extender that keeps leaking.
The leaking is mild, a simple cloth wrapped around the valve is fine, but I did try to tighten it further, but it's causing the pipe to bend, and I fear ill permanently damage the pipe and flood the house with water.
So I'm left with an option, figure out a way to stop the leak myself, but I don't know how, any advice..
Or....I call a plumber, any idea how much that should cost to replace/fix a valve?
Cheers!
Cheers!
