Neff 5340X0GB/04 Washer Drier drain problem
19 Nov 2012
Newcastle upon Tyne
I have a problem with our washer drier in that it will not operate correctly when loaded with two bath towels.
The problem manifested itself with an error EO6 which with posting of zipper 20 Nov 2009 I was able to diagnose a problem with the water pump, the bearing is worn and the impeller wobbles around but it still works. Unfortunately I got the wrong askoll and had to rebuild the washer drier without checking that the sump was clear.
Before I buy the correct part I would appreciate that the problem is only due to a blocked sump
