Hi
This started a few days ago where I assume the dishwasher tripped RCD (nothing else particularly on at the time).
We’ve now noticed it won’t finish the cycle and tap light is on, but nothing getting warm either. It probably gets through about 3/4 cycle.
It seems to be pumping water out fine, I started off checking for any impeller blockages (before I realised no heat either).
I put meter on heat pump and it’s reading 20 ohms so believe all ok there.
So now wondering if relay issue on PCB.
Mine is located back right hand side at bottom of machine (unfortunately not in door). Only I can’t get it undone from the back.
Any other ideas before I go into battle trying to get that out? Can’t find a single video which shows this.
Either that or just cut my losses as 8 yrs old anyway!
Thanks.
Thanks.
