Nest Heat Link to Potterton
14 Dec 2023
Hi
Does anyone have any instructions or a diagram of how to connect the heatlink to a Potterton Boiler. It just has a built in mechanical clock and never had any form of thermostat previously
TIA
Prash
Is this Potterton heat only, system boiler or combi? (I suspect the latter). Make/model?
Ok, I’ve had a look, will be simple enough, assuming Nest 3rd generation learning thermostat, then obtain some 5 core heat resistant flex cable piggyback L N E from the boiler and use terminals 2 & 1 to 2 & 3 on the heatlink, Park the earth in a chock block/terminal strip connector
