Long story short, i am in the process of routing network/cat5 cables through the house for a home network.
I looked into dropping them down the cavities of the house. From the loft down - drilling through thermalite block - i found a lot of debris within the 'air gap' cavity, and noticed it was all Celotex insulation.
I routed the cables internally instead, then went back to the routing them down the cavity form upstairs bedroom down into lounge below. I had more luck here and dropped the 'fishing line' down several feet without too much issue - took a while though. HOWEVER, when I pulled it up it had a yellow fibre type fluff attached to it which it had obviously been dragged through. Not enough to suspect damage but it definitely wasn't celotex, despite effectively being in the same cavity- only at the bottom.
Now I ask more out of curiosity then anything. House has been standing for 7 years problem free (touch wood) and being a new build, if my house is like this I imagine most new builds are... if corners can be cut they will be cut in the haste of putting the houses up quickly & cheaply etc.
I have a 25 year guarantee from Rockwool and 4 years left of the useless NHBC. The cavity insulation looks similar to the stuff found in the loft.
I will try and post pics this evening.
Can anyone comment? - cheers
