New flat - electric water heater thermostat problem
16 Apr 2009
Warwickshire
This is my first post so hello to everybody! I am not a plumber or anything, but I'm interested to discover whether I can do anything about this issue myself.
I have just bought and moved in to my first property! :D
The flat runs on Economy 7 electricity (no gas) and the hot water comes from a Heatrae Sadia Megaflo HE water heater tank and this is fitted with 2 Cotherm TSE thermostats, one for the on-peak and one for the off-peak elements.
I have set the controls up correctly to heat the water for a period of three hours during the early morning when the off-peak electricity is in effect.
Annoyingly the red safety button on the off-peak thermostat keeps tripping and I have to press it back in every day. Once I do this the water heats normally and all seems fine. The red dial on the thermostat has a range between 1 and 5 and is currently set to 4. Not sure what this means, possibly the heat at which the thermostat turns the heating element off?
The on-peak (boost) heater works fine and the thermostat for this doesn't trip.
I wanted to just scout around the possible causes before having to resort to calling in a plumber (the expense of which I could do without right now having bought the place and kitted it out with furniture).
Thanks for any advice you can offer.
Graham
sounds to me like the thermostat in the off peak immersion has gone, not a major job to change.
