Hi. just wondering if anybody could help as not certain if all these problems are connected or if I am just having a run of bad luck.
Around 6 weeks ago I had a leak in my hot water cylinder which flooded through the ceiling. The system was drained down partially and isolated, leaving us with cold water but no heating or hot water.
Fast forward 5 weeks and I eventually got somebody in to replace the cylinder. It was replaced with a telford 1050x400 cylinder as a direct replacement. When the old one was disconnected there was still some water inside which again leaked, and in the process of removing it the electric box in front of the cylinder was damaged (since been replaced and the wiring redone)
When the boiler was fired up again there was an issue and all the electrics tripped, with the installer saying the ch pump had seized and needing replacing. This was done and now we have heating and hot water.
Since then the following has happened.
No water comes out of the shower at all but it was working before the cylinder leaked. Been in the attic and the isolation valves to the pump are open (salamander ct75 twin pump) and there seems to be power going to it (cable has been checked and lighting up)
My freezer still has power going to it when it is plugged in however it has now stopped freezing anything and so thinking it will need replacing
Gas double oven now has no gas coming to it and is not igniting. When it is turned on the lights inside usually come on however they are not working either. However the gas hob is still igniting and working.
Smiths under cooker heater blowing out cold air however not hot air.
Electrics repeatedly tripping out, usually when trying to light the cooker but also other times.
Sorry for the long post but wanted to try and give all the info. Due to the amount of stuff going wrong wondering if it is all connected however maybe im just having a lot of bad luck.
Any advice?
Any advice?
