Hi people, i hope you can help
Like an idiot, I put a nail through a microbore pipe situated under one of my radiatiors, last night (i don't know whether it was a flow or return). To see me through the night i put the nail back in and it didn't leak overnight.
Anyways i obviously needed to drain the water in the pipe so i switched of the central heating system and the main incoming water feed, ran the cold water until it was no more and attached a hose and drained the radiators from one of the drain plugs attatched to the left hand valve of the radiator. (I realise i've probably done it totally wrong)
i repaired the pipe, reconnected the water and switched on the central heating system, tightened everything up but there is no hot water or heating.
I have a Ideal Classic RS250 boiler and i think i have a fully pumped open vented system (I have a DHW Cylinder in a cuboard and a Feed and Expansion tank in the loft)
Anyone any ideas what i can do?
Regards
Ian
Regards
Ian
