I've just had a shower put in with a Salamander pump in the loft. It's been ok the last few days but tonight I used it and after switching off the shower mixer, I could hear the pump repeatedly powering up and down, as if it thought I was switching the shower off and on repeatedly. It didn't stay on continuously, but kept going on and off.
I switched the electricity off at the mains for a second, then on again and it carried on doing the same thing.
Then back in the shower, I turned the thermostat switch down to a lower temperature and that finally made the pump stop.
After a bit I turned the thermostat back to the original higher temperature, tested the shower and this time the pump stopped as it should.
Any ideas why this happened and do I need to get the plumber back in? This is only the first time it's happened but I wonder if it's a sign of a problem? Just what I need before Xmas!!
