Thanks for looking and appreciate anyhelp
Now that Winter is approaching, I have set the HW and CH programme to start at same time, the HW programme is to set to stop after 1 hour and the CH to run on for another 3 hours. Previously the CH was off.
However the CH only runs for the same time period as the HW programme.
Boiler switches off but Programme light still shows active for CH.
The Valve is a Honeywell Mid-Position Valve 22mm
Following threads I replaced the Syronised Moter, However Problem still persists
1) I wondered it it had anything to do with the connectors to the Synchronous Motor ie two wires connecting to two other wires, does it make any difference which way it connected.
2) Or any diagnostics I could undertake incase it was the Vavle itself or another part of the system.
The system as far as I can tell is gravity fed oil fired boiler.
There are no room temperature thermostats. Only Thermostat is attached to the Hot water Tank.
