I have posted already on this subject but possibly I didn't explain fully.It is a Ravenheat 84ET and altho' I have fitted a new genuine Giannoni Diverter the problem remains.I can fire up on DHW but only if I tap the valve.This was also the case with the original valve.The sequence therfore is:-
Turn on DHW/Fan and pump operate but no ignition/Tap the valve 3 times and it fires up.Theoretically,the original valve was OK because we also had to tap that.At the moment due to kitchen fitment etc. we are using the boiler purely for DHW,(in effect as an instant hot water heater).Pressure is maintained at 1 bar but only one radiator connected.The boiler eventually is to be relocated in an upstairs utility room.The reason for posting mainly is that if we are looking at an expensive repair then sensibly we will just have a replacement boiler installed when we relocate it upstairs.
