Hi peeps
Am decorating our dining room which is an extention to the existing house. We have only lived here for 18 months and the extention is about 10 years old.
The sparkey (and I use the term looseley) who wired up the extention has extended a radial circuit which is on a 32A breaker and only has one double socket and the boiler on it in the original part of the house.
This then powers two single 13A sockets and the lighting for the extention using 2.5mm T&E. The radial has then been extended out using 6mm T&E to a CU in the garage to provide power for one 13A socket and two lights in the garage. It is not fused using a FCU before it leaves the house, which I plan to change.
My problem is that once in the extention there is no earth to any sockets or lighting.
I presume the only thing I can do to make this safe is to run new T&E cable and reconnect to the orignal part of the house?
Any suggestions would be appreciated.
Many thanks
Sam
Many thanks
Sam
