Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
I,m trying to get a permanent electric supply to my loft so i can plug in my ariel splitter but cant find anything apart from cable to lights,can anyone help, Misses going up wall no tv in bedroom.
I,ve found a electric cable going to a timed fan with brown,black,grey and earth. My question is can i wire a single socket onto it the run my ariel splitter and if so which wires.
This would be the best action.
Take a spur to a FCU with a 3amp fuse in it. If the booster has a power lead, wire it into the load side of the fcu, if it is a plug in type, wire a socket to the load side of the fcu and label it as "TV Booster Only"
