You don't use drain cock to get air out, that is done by rad vents, expansion pipe to F&E tank and any aav's on the system... Check to see if you also have any manual bleed valves located anywhere.
As long as the F&E tank has water in it and the ball valve is working so that it can 'top up', then the 'head' of water should force air to gather at high points and inverted loops ie top of rads.
If all is working except 2 rads then check the pins on the TRVs for these rads - they may be stuck and need manipulating with pilers/ small tap with hammer.
Check pump works correctly.
And you may have blockage to those defective rads.
