I have a Camray 5 oil boiler that had no power to it. I had a plumber out for 3 hours and decided that it was "probably" the programmer and it would be cheaper for me to replace this myself. I did replace it .. ( Honeywell ST9400C 2 channel) and yes there is power getting to the boiler but when it was fired unfortunatley after approx 5 min the boiler stopped and there was a knocking in the loft space and boiling water was gushing out of the overflow. The boiler refused to start although there was power getting to it and I had to wait several hours and then it would allow me to reset it before it would re-start and the same thing happened again. I also changed the 3 way mid position valve head but the same thing happens. I have no hot water as it goes straight out of the overflow and there is no heating either. The programmer has a wireless thermastat and I have checked that this is working.
The pump seems ok...( Grundfos Alpha2 L ) as there is power getting to it and it registers on setting PP2 I can hear water running through the water cylinder but no hot water.
Can anyone give me any suggestions as I am pulling my hair out !!!
