Boiler: Gloworm Ultimate 50FF
System: Gravity Fed
Hello, new to the forum but I am in need of some help. As you can see from the subject title I have no hot water
I get a bit of hot water if I have the heating and water hot set to both be on constant (expensive
). If I have the hot water only on then the boiler gets hot and then turns off after a couple of minutes
I have had a look in the loft. The small F+E tank next to my cold water storage tank is full of water, and the ball valve isn't stuck or anything. However, my F+E tank is slighlty bowing which does worry me
Anybody got any ideas. I was thinking it may of been a blocked cold feed, but I am guessing it is more than likely the cylinder
Cheers
System: Gravity Fed
Cheers
