- Joined
- 18 May 2021
- Messages
- 3
- Reaction score
- 0
- Country
Hello everyone,
Please can I have your advice on the following hybrid configuration that involves vented heating & un-vented hot water ?
I currently have a regular boiler (Worcester Greenstar 24 RI) running in a vented system, with cold water storage tank in the loft and also an heating F&E tank in the loft, pumped into a Y configuration that uses an indirect vented hot water cylinder.
The goal is to get rid of the cold water storage tank in the middle of the loft.
My suggestion to my plumber, to do this as cost effectively & efficiently as possible, is to keep the heating side as-is, i.e. keep the existing regular boiler; pump; heating F&E tank; Y configuration etc. but replace the existing vented indirect hot water cylinder with an un-vented indirect cylinder (Tribune HE) on the hot water side, with all the safety bits that go with this.
I'm happy to accept the risk of higher pressure on the hot & cold water copper piping, but see no reason why the heating has to also be pressurised as well.
