Noise when hot water is Run can anyone help!
3 Apr 2007
Lanarkshire
Hi I have a typical hot water installation conisting of a normal boiler, copper hot water storage tank and cold feed tank above within the loft.
When I run the hot water, noise is made from within the airing cupboard where the cylinder is, like a hissing noise.
I think the pipe which is making the noise is the mains cold water pipe which feeds the water tank within the loft.
Does the problem lie within this pipe e.g corrosion or could it be a problem with the tank e.g the ball value???
P.s. it not a hammering sound
Has this just started to happen or has it always been like it.
Have you had reason to turn /adjust the main stopcock recently. If so you may have it turned either up to much or to little and disturbed the status-quo.
The odd vibration can cause all sorts of wonderful noises. :shock:
If not, then change the ball cock for one that is supposedly silent. Can't think of the name of it, works on the principle of water (back pressure) pushing the diaphragm against the shut off pin. not like the old ballcock. :)
I don't think its always done it, its just one of those things that one day you don't notice it and the next day you do. Don't think anyones touched the stop cock but I will try adjusting it.
A new value maybe the solution, we will have to see.
HI, IF THE NOISE SOUNDS LIKE THE TITANIC COMING HOME, IT COULD WELL BE THE BALL AND FLOAT VALVE RESONATING, REPLACE IT AND IT SHOULD STOP.
