noisy combi boiler
1 Sep 2006
Apologies if this as been posted before. Should my extraction pump from my boiler a worcester bosch 28i make an high pitch squeal when it pumps out the condensed water.
Frankly Dolly, a condence waste pump should not be screaming whilst pumping.
pump bearings might be on ther way out :shock:
Edit typo :oops:
Agree with clf. Usually just an audible whirring noise.
What make is it?
Thanks for the replies, turns out it was a sticky float within the pump, a good technical tap and a refill seems to have sorted it out, it is still a little noisy so maybe the fact it ran dry may of damaged the bearings, i'll keep an eye on it.
