Recently my boiler started to make loud kettling noies. I flushed the system with clean water. The expansion tank was also full of muck so drained and thorougly cleaned it.
I then added X400 to the system. Within a day, there was no noise from the boiler. I left the X400 in for 1 week, then drained the system, and gave it a good flush by shutting the rad valve (next to the drain point) and opening the other valve, so water was flowing across the bottom of the radiators (Downstairs ones). I then refilled the system, and added 1L of X200, and 1L of X100.
Now my boiler bangs as loud as before!
I cannot beleive it is the oxygen in the fresh water, as when I flushed it the first time it was ok.
Could it have flushed some debris into the boiler?
Would it be worth removing the boiler and flushing "on the floor" with a pressure washer?
